MWI problem for GDM in a CUE7
Jun 3rd, 2010
I've configured a GDM that works fine in my CUE7.
But my problem is that :
1 - the group member doesn't see the MWI : I've already read the CUE Design Guide, saing that I should use the second line of the phone.
But after trying, the MWI is still off. The GDM primary extension is configured as a DN in the CUCME.
2- The MWI is not ow if I call the MWI number. For example : the MWI = 1998.... and 1999...., then it cannot be called. The phone play busy call.
Is there any solution
Best regards,
Antra
Overall Rating: 5 (2 ratings)
Rob Huffman Thu, 06/03/2010 - 06:07
Hi Antra,
Can you please provide the GDM extension and the extension configured
on LIne 2
Also, check for this config on CME;
In Cisco Unified CME 4.0 and later versions, you can designate a  phone line other than the primary line to be associated with the MWI  lamp.
Step 1
enable
Example:
Router> enable
Enables privileged EXEC mode.
Enter your  password if prompted.
Step 2
configure terminal
Example:
Router#  configure terminal
Enters global configuration mode.
Step 3
ephone phone-tag
Example:
Router(config)# ephone 36
Enters  ephone configuration mode.
phone-tag Unique sequence number that identifies  this ephone during configuration tasks.
Step 4
mwi-line  line-number
Example:
Router(config-ephone)# mwi-line 3
Selects a phone line  to receive MWI treatment; when a message is waiting for the selected  line, the message waiting indicator is activated.
line-number  Ephone line number. Range is 1 to 34. Default is 1.
Step 5
end
Example:
Router(config-ephone)# end
Returns to privileged EXEC mode
Hope this  helps!
Rob
iantra123 Tue, 06/08/2010 - 07:10
After some troubleshooting, the MWI works fine for each user, but not for the GDM.
Should I configure the GDM number as Line?
I ask this because the GDM Line is a Hunt Pilot.
So if I'll configure a line for this hunt Pilot then my second line will ring.
ephone-hunt 1 sequential
pilot 6305
list 1000, 1001, 1002, 1003, 1004, 1005, 1006, 1007
final 6329        !!!!!! VOICEMAIL PILOT
timeout 10, 10, 10, 10, 10, 10, 10, 10
description HelpDesk
dial-peer voice 100 voip
corlist incoming cssemployee
description To VMail
destination-pattern 6329
session protocol sipv2
session target ipv4:CUE_IPAddr
dtmf-relay sip-notify rtp-nte
codec g711ulaw
no vad
Support Albakom Thu, 06/03/2010 - 06:59
my 2 cents to point 2: if you can't call the mwi on and off numbers the phone or the line  doesn't have the permission to do this. set the mwi numbers in a partition who is reachable for the phones or lines.
