Cisco SRST Configuration
Jun 3rd, 2010
Hi every body ,
I'm trying to configure SRST on cisco 2850  router ,
We have a PRI Linge without DID option with number : 71103300
the pb is  for the incoming calls  : the caller faces a  dial tone and the call is not transferred the extension 3078
this the print out of the dial rule
voice translation-rule 1
rule 1 /^70103300/ /3078/
voice translation-rule 2
rule 1 /^02/ /2/
rule 2 /^07/ /7/
rule 3 /^09/ /9/
rule 4 /^04/ /4/
rule 5 /^05/ /5/
voice translation-profile SRST-IN
translate called 1
voice translation-profile SRST-OUT
translate called 2
Can any one help me .
Jonathan Schulenberg Thu, 06/03/2010 - 04:24
  • Cisco Designated VIP,
    2017 IP Telephony
Your incoming dial-peer needs to have the direct-inward-dial command present on it.
HatemCisco2010 Sun, 06/06/2010 - 05:38
Ok thanks Jonathan   for your help , but is there any trick or a command  to configure  without the need of the DID ?
Jonathan Schulenberg Mon, 06/07/2010 - 05:39
    2017 IP Telephony
No and I suspect that you misunderstand what the direct-inward-dial command does. It only prevents secondary dial-tone which is what you are experiencing. The default behavior of CME when an incoming dial-peer is matched is to provide dial tone so the caller can enter the destination address they desire. This command states that whatever the destination address received when the dial-peer was matched is the destination address for the outbound call leg and does not offer additional input opportunities to the caller.
HatemCisco2010 Mon, 06/07/2010 - 06:39
I should thank you Jonathan for  your support .
Thanks   again .
HatemCisco2010 Mon, 06/14/2010 - 07:24
Hello ,
My friend found a slution without the need of DID , you can find  here the command
rule 1 /^.*/ /3078/
Have a  nice day .
