Does ODR support split tunneling? (On-Demand Routing)
Jun 3rd, 2010
Mudassir
Federico Coto F... Thu, 06/03/2010 - 06:46
Very good question!
My gut guess is that it should work because split-tunneling is just a rule that applies to which traffic is going to sent through the tunnel (it is not directly dependant of the routing table).
However, I have not done it to assure you that it will work.
What are you trying to do?
Federico.
Federico Coto F... Thu, 06/03/2010 - 09:44
Yes I see the document... however it does not explain why ODR does not support split-tunneling, it just say it doesn't.
Are you planning ODR with split tunneling in your setup?
Federico.
