RSS not displaying correct characters - DMM 5.2
Jun 3rd, 2010
Hi all,
I have recently bumped into the following issue.
I have setup the php proxy and tested it using various rss feeds (e.g google) with success.
Though, if i try to load some Greek Rss Feeds i get some really strange(unreadable form,mixed characters etc) rss feeds strolling in our LCDs.
Someone could tell that Greek Fonts are not currently supported by DMM 5.2 but i can only say that while being under 5.1 we could retrieve and display Greek Rss Feeds with success.
What has really changed to 5.2 version?
Is this a limitation of flash???
Thank you all!
Overall Rating: 4 (1 ratings)
Tomas De Leon Thu, 06/03/2010 - 10:51
  • Cisco Employee,
There are some issues with different Language support in Digital Media Designer(DMD).
Greek is not supported in DMD.  If you use and external application to develop the
web presentations the Greek Language ** should ** be displayed correctly.
I can display the following page without issue (I believe)
http://www.enet.gr/
T.
Tomas De Leon Thu, 06/03/2010 - 12:22
  • Cisco Employee,
I tried
http://www.sigmalive.com/rss/latest/7
via the Web Browser plane and it appears to display the Greek
with no issues.
As I noted before, the problem is with Digital Media Designer(DMD) in
5.2.  Greek is not supported.
If you create a web page or presentation with RSS feed (greek) with a
"Different" tool or application it ** SHOULD ** work.
Try and let me know if it works or not..
T.
panayiotiscy Thu, 06/03/2010 - 13:41
Is it possible to explain this a bit more?
Because i create a presentation through DMD using the greek rss link but i dont get anything readable.
Tomas De Leon Thu, 06/03/2010 - 14:21
  • Cisco Employee,
I don't think you are getting what I am saying.
You can NOT use DMD for creating presentation.
DMD does NOT support Greek Language therefore
the presentations will NOT display correctly.
What I am saying is use a DIFFERENT tool or application (NOT DMD)
to create the presentation using greek and it SHOULD work.
If you have it, try something like Adobe Dream Weaver, etc...
T.
Related Content
