Network Modules and 2610XM
Kevin Brennan
Hi All,
I was wondering if anyone can clarify if the NM-1FE2W or NM-2FE2W will work in the 2610XM?
These two pages seems to contradict each other:
http://www.cisco.com/en/US/products/hw/routers/ps259/products_relevant_interfaces_and_modules.html
http://www.cisco.com/en/US/prod/collateral/routers/ps259/product_data_sheet09186a00801aa71c.html
I've an option on some 2610XM's cheap for my lab, but I need to have 2FE ports in each. Some people have told me the NM-1FE2W and NM-2FE2W will work in the XM's and some others have said they wont!
Any help would be great.
Thanks in advance.
Kevin
5 Replies 5
Leo Laohoo
Look under Table 5.  Make sure have the correct IOS version with right feature set.
Ganesh Hariharan
Hi All,
Thanks in advance.
Kevin
Hi Kevin,
The "Portable Product Sheet - Module Crossref" confirms - no support for NM-1FE2W in the 2600XM routers. The NM-1FE2W is only supported in the 2691, 3620, 3640, 366x, 3725, 3745, 3825, and 3845 routers.The only supported LAN Network Modules in the 2600XMs are the NM-1E, NM-4E, and NM-16EWS. The only supported "WIC Slot Adding Network Modules" in the 2600XMs is/are the NM-2W.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Hi Leo, Ganesh,
Thank you for taking the time to reply to my post.
I'm still none the wiser though!
--Leo,
Table 5 does indeed imply that they will work. But then table 3 implys that they wont!
I think I might have to take a chance and get my hands on one. If all else fails, I can still use it as a BBR.
I'll post back if/when I get a result.
Cheers guys.
Kevin
Hi All,
Just for information, the NM-1FE2W (as expected!) doesn't work in a 2610XM with a 12.4T IOS
The NM-1E's work fine though.
Kevin
markmckee601
I was in a similar situation. Even if the wireless module(s) are supported, a used 800 series router with built in wireless works out about the same price as just the wireless module.
Wireless modules:
     HWIC-AP-G - $150 (approx.)
     HWIC-AP-AG $169 (approx.)
*prices from eBay - 29/03/2013
Cisco 871W 4-Port 10/100 Wireless Router - $100 + $15 shipping
I ended up buying an 800 series (871w) router.
Hope this helps.
