5510 startup and configuration
Jun 3rd, 2010
I have a cisco asa 5510 which I am attempting initial setup.
I have connected it to a cisco SG 100D-08  switch using the 5510's MGMT port.
I have connected a laptop windows XP to the SG 100D-08 as well.
I set the IP address of the laptop:
192.168.1.2
255.255.255.0
gateway: 192.168.1.1
I use internet explorer 8 on this laptop.
https://192.168.1.1/  does indeed communicate with the 5510I leave the login/passwd blank and then Enter
click ok to accept all certificates on their dialog boxes...
I click run ASDM as java applet,
new screen comes up: CISCO Adaptive Security Device Manager,
then java screen: Authetication Required.
again, I leave login and passwd blank, click ok
this releases the java authentication screen and then the
security device manager screen populates with info:
ASDM version 5.0 (8)
ASA version 7.0 (8)
User: <admin>
privelege level 15
Java script enabled
java enabled
Browser Internet Explorer
Browser version 8.0
Java Version 1.6.0_20
OS windows XP 5.1
Do not close this window
Cisco ASDM 5.0 for ASA will start in another window. Closing this browser window will cause Cisco ASDM to exit.
please wait. Main window is coming up
<status bar grows to 100%>
from there, nothing... thatASDM never opens another window and therefore never starts?
what is happening?
...I do not have pop up blocker on... it is turned off.
what else can I check?
Overall Rating: 5 (3 ratings)
todd-nash Thu, 06/03/2010 - 06:18
also, if i use the:
Download ASDM Launcher and start ASDM
asdm launcher does indeed, download to my computer and runs, but when I  OK
the ip address screen with blank login/passwd,
the login screen disisses and no ASDM manager ever comes up.
David Hornstein Sat, 06/05/2010 - 16:13
  • Gold, 750 points or more
What would happen if you reset to factory defaults as per the URL below ? (assuming you can get access to the CLI of the ASA5510)
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/start.html#wp1053876
I would also be inclined to download the latest ADSM and run set it up on your XP machine after you performed the reset to factory defaults as yourlined in the link above.
It's one suggestion, but netpro must have logged a lot of similar enquirees like yours.  Why not also search  NetPro for similar questions posed by other folks, if this procedure doesn't satisfy your needs.
regards Dave
todd-nash Wed, 06/09/2010 - 12:04
console cable and hyperterminal connect fine....
alyhough I know very little of the command line instructions, I was able to reset to factory defaults:
ciscoasa(config)# confif factory-default 192.168.1.1 255.255.255.0
runing asdm still does not work. I have downloaded 6.2 ASDM
what next?
I know nothing of netpro?
what is that?
todd-nash Wed, 06/09/2010 - 12:36
a couple listings from the CLI:
ciscoasa(config)# dir
Directory of disk0:/
5         -rw-  5548032     00:05:40 Jan 01 2003  asa708-k8.bin
683     -rw-  4181246     00:05:58 Jan 01 2003  securedesktop-asa-3.2.1.103-k9.pkg
1194   -rw-  398305      00:06:12 Jan 01 2003  sslclient-win-1.1.0.154.pkg
1243   drw-  0           13:47:38 May 16 2010  crypto_archive
1245   -rw-  6163744     13:48:54 May 16 2010  asdm-508.bin
255426560 bytes total (239050752 bytes free)
ciscoasa(config)# sh asdm image
Device Manager image file, disk0:/asdm-508.bin
ciscoasa(config)#
ciscoasa(config)# show ver
Cisco Adaptive Security Appliance Software Version 7.0(8)
Device Manager Version 5.0(8)
Compiled on Sat 31-May-08 23:48 by builders
System image file is "disk0:/asa708-k8.bin"
Config file at boot was "startup-config"
ciscoasa up 7 days 4 hours
Hardware:   ASA5510, 1024 MB RAM, CPU Pentium 4 Celeron 1600 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash Firmware Hub @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
                             Boot microcode   : _CNlite-MC-Boot-Cisco-1.2
                             SSL/IKE microcode: _CNlite-MC-IPSEC-Admin-3.03
                             IPSec microcode  : _CNlite-MC-IPSECm-MAIN-2.05
0: Ext: Ethernet0/0         : address is 5475.d026.e814, irq 9
1: Ext: Ethernet0/1         : address is 5475.d026.e815, irq 9
2: Ext: Ethernet0/2         : address is 5475.d026.e816, irq 9
3: Ext: Ethernet0/3         : address is 5475.d026.e817, irq 9
4: Ext: Management0/0       : address is 5475.d026.e813, irq 11
5: Int: Not used            : irq 11
6: Int: Not used            : irq 5
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited
Maximum VLANs               : 25
Inside Hosts                : Unlimited
Failover                    : Active/Standby
VPN-DES                     : Enabled
VPN-3DES-AES                : Enabled
Security Contexts           : 0
GTP/GPRS                    : Disabled
VPN Peers                   : 150
This platform has an ASA 5510 Security Plus license.
Serial Number: JMX1420L42C
Running Activation Key: 0x6d0ced7a 0x58ed117c 0x38630db4 0x9b00dc3c 0x803a3ca2
Configuration register is 0x1
Configuration last modified by enable_15 at 10:19:49.686 UTC Wed Jun 9 2010
Weird issue. I'm experiencing the same problem with a brand new 5510. I try to connect using the ASDM but after logging into the ASDM the window closes. I tried reinstalling Java with the latest version available at java.com, have reset the device to factory default a few times.
When I launch the HTTPS site it's the same thing. I get prompted for a password then after entering I get a notice saying "please wait... Main window is coming up" and the progress bar goes to 100% without anything else happening. I've left that window open for 30 min now with no change.
I've tried using several browsers (IE, Firefox, Chrome) and have now tried with more than one computer as well. I'm getting responses when I PING the interface.
ciscoasa up 3 hours 4 mins
                             Boot microcode   : CNlite-MC-Boot-Cisco-1.2
                             SSL/IKE microcode: CNlite-MC-IPSEC-Admin-3.03
                             IPSec microcode  : CNlite-MC-IPSECm-MAIN-2.05
0: Ext: Ethernet0/0         : address is 5475.d0ba.525e, irq 9
1: Ext: Ethernet0/1         : address is 5475.d0ba.525f, irq 9
2: Ext: Ethernet0/2         : address is 5475.d0ba.5260, irq 9
3: Ext: Not licensed        : irq 9
4: Ext: Management0/0       : address is 5475.d0ba.5262, irq 11
Maximum Physical Interfaces : 4
Maximum VLANs               : 10
Failover                    : Disabled
VPN-DES                     : Enabled
GTP/GPRS                    : Disabled
VPN Peers                   : 50
This platform has a Base license.
Serial Number: JMX1421L4J9
Running Activation Key: 0x9e0fff67 0xa8a92bb7 0x38105154 0x887ca8ac 0xc00e2886
Configuration last modified by enable_15 at 11:33:03.217 UTC Thu Jun 10 2010
todd-nash Thu, 06/10/2010 - 12:36
David,
I had the opportunity to use a brand new computer with fresh operating system install...
I used internet explorer 8
and pointed it to the 5510: 192.168.1.1
It gave me an error about no Java runtime installed, so I used the cisco link and installed
Java 2 runtime environment, SE v1.4.2_07
and ASDM worked fine on that computer.
Maybe having the latest Java is not such a good thing?
You beat me to updating this post. I discovered the same thing. I downgraded to 5.12 on my admin machine and that's fine now. I tried a few more computers (I hop around to a lot of machines) and one with 6.2 (I think) was fine. Another with 6.10 (I think) didn't work. Very confusing but I'm glad there's finally something consistent and this workaround is acceptable.
William Benson Tue, 04/05/2011 - 08:36
Holy Cow...Thanks guys!! I was beating my head against the wall on this one.  I found an ASA 5510
sitting in the corner here at my new job collecting dust.  So I decided to mount this joker and start using
it, apparently they bought it 2 years before I was hired but the guy before me couldn't figure out how to
configure it.  Any rate I was really getting frustrated that the java app wouldn't load.  I could see the process running but the GUI would just never come up.  I uninstalled Java 6 and rolled back to an older version and BAM! I'm in like Flynn!  Thanks
