06-03-2010 07:55 AM - edited 02-21-2020 04:40 PM
I need some help configuring management access to an ASA 5510 from my workstation when connected via the AnyConnect client. The VPN works fine and I can connect to anything at the remote site, but it won't allow ASDM / SSH to the ASA from the remote side of the tunnel. I have an assigned IP so my workstation always has the same address, and I have management access allowed from that address on both the inside and outside interfaces. But I must be mising something. No problems with management access from inside the network. Thanks for any help.
Solved! Go to Solution.
06-04-2010 06:15 AM
If you are trying to access the inside interface of the ASA over the VPN tunnel, then please add the following:
management-access inside
You would then need to add the following as well:
ssh
http
Hope that helps.
06-04-2010 06:15 AM
ssh
http
Hope that helps.
06-04-2010 06:34 AM
That did it. Thanks very much.
