"Sh ppp multi int multi X" output
Jun 3rd, 2010
Could someone please let me know if "unassigned" fragments indicate an issue on a multilink ?
See output below:
Multilink9, bundle name is XXX
  Bundle up for 1d12h
  0 lost fragments, 2861459 reordered, 23 unassigned
  0 discarded, 0 lost received, 2/255 load
  0x60AF3B received sequence, 0x9E46A7 sent sequence
  Member links: 4 active, 0 inactive (max not set, min not set)
    Se2/0/17:1, since 1d12h, last rcvd seq 60AF40
    Se2/0/18:1, since 1d12h, last rcvd seq 60AF65
    Se2/0/16:1, since 1d12h, last rcvd seq 60AF62
    Se2/0/4:1, since 1d12h, last rcvd seq 60AF37
Thank you.
Lynne
John Blakley Thu, 06/03/2010 - 08:32
I don't have that problem with my multilinks, but I've disabled fragmentation. Are you having an issue with the link?
HTH,
John
lkadlik Thu, 06/03/2010 - 08:41
Hi John,
I am trying to figure out if we are having an issue or not. I have a customer complaining of latency to an app.  I can see the sporadically high ping times and hops in a traceroute though those can be false positive.  All the circuits are running clean and nothing is being dropped.  The only thing I saw that seemed odd is the "unassigned" fragments in the output in the post. I dont know if I should be concerned about them or not.  I searched for a while on google and could not find out anything one way or another.
Lynne
John Blakley Thu, 06/03/2010 - 08:44
Can you post the config of that interface and the interface that's bonded to it? Take out public addressing and things....
John
lkadlik Thu, 06/03/2010 - 09:07
interface Multilink9
description to -
ip vrf forwarding XX
ip address x.x.x.x 255.255.255.252
ip flow ingress
no cdp enable
ppp multilink
no ppp multilink fragmentation
multilink-group 9
no clns route-cache
end
sh run int Se2/0/18:1
Building configuration...
Current configuration : 235 bytes
interface Serial2/0/18:1
description T-1 to -
bandwidth 1544
no ip address
ip flow ingress
encapsulation ppp
ppp multilink
multilink-group 9
no clns route-cache
end
sh run int Se2/0/17:1
interface Serial2/0/17:1
description T-1 -
bandwidth 1544
no ip address
ip flow ingress
encapsulation ppp
ppp multilink
multilink-group 9
no clns route-cache
end
sh run int Se2/0/16:1
interface Serial2/0/16:1
description T-1 to-
bandwidth 1544
no ip address
ip flow ingress
encapsulation ppp
ppp multilink
multilink-group 9
no clns route-cache
end
sh run int Se2/0/4:1
Current configuration : 222 bytes
interface Serial2/0/4:1
description T-1 to
bandwidth 1544
no ip address
ip flow ingress
encapsulation ppp
ppp multilink
multilink-group 9
no clns route-cache
end
here you go.
