WebAuth Redirect URL Duplication
Jun 3rd, 2010
Hello
I have WLC2106 with sw 4.2.205.0 and have enabled webauth, such that any users first attempt to connect to the internet will be intercepted as expected.
This works fine if going direct to a link with NO proxy, and it works fine if adding ":8080" to the end of the url as well.
I have the following problem though if I specify a proxy server in my IE settings (IE7).
I go to open a web page
http://192.168.1.1
get redirectected to
https://10.1.1.1 of the WLC, correctly so, however, the actual URL appears like this:
https://10.1.1.1/login.html?redirect=192.168.1.1http://192.168.1.1
so, once authenticated, which works fine, the redirect will try to pass the user to the website
http://192.168.1.1http//192.168.1.1   (note the obvious duplicate in the address, but also the missing : in the second url)
This does not happen when the proxy server setting is turned off and I have put the WLC virtual address in the proxy bypass list.
I have also tried both with and without an address in the "Redirect URL after Login" text box.
Has anyone experienced this, or, does anyone have any idea what it might be?
Thanks in advance
Anthony
Related Content
Trending Topics - Security & Network
