Dialing timeout/delay when keying digits
Jun 3rd, 2010
Is there a way to change the delay before the digits dissappear on an SPA525g.  For instance if I start to dial a number so I dial 91510 and then get interuptted for a second the number disappears and I have to dial it from the beginning.  It looks like it gives about 10 seconds to complete input of the number.  We would like to up the timeout if possible.
Brandon Buffin Thu, 06/03/2010 - 10:42
  • Purple, 4500 points or more
Yes, you can change the interdigit timeout using the following CLI command:
router(config)#telephony-service
router(config-telephony)#timeouts interdigit 20
This would increase the interdigit timeout to 20 seconds (default is 10).
Hope this helps.
Brandon
