Replacing NM-HDV2 card by VWIC2-1MFT-T1/E1
My customer is planning to replace an existing NM-HDV2-1T1/E1 card (connecting a TDM PRI trunk from PBX) by a VWIC2-1MFT-T1/E1 card.
I just want to know if a standalone VWIC card can support all the voice functionality of a NM-HDV-T1/E1 card including E1 PRI signalling.
There are enough DSPs onboard the Cisco 2821 router.
Many thanks for your time.
NS
Rob Huffman Thu, 06/03/2010 - 10:21
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi NS,
Yes, the VWIC2 - 1MFT -T1/E1 card can fully support E1
PRI signalling We use 4 of these cards to support a similar
setup.
Cisco 2nd Generation 1 and 2 Port T1E1 Multiflex Trunk Voice WAN Interface Cards
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/prod_qas0900aecd8028d2e5.html
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
