routing outbound calls thru specific voice ports
Answered Question
Jun 3rd, 2010
I have a CME systems that has both SIP and analog PSTN trunks. I would like outbound calls from IP phones to go out the SIP trunks.  I also want to attach a FAX to an ATA device but I need to send FAXes out the analog ports since FAXes over SIP doesn't work to well.  HOw can I do this?
Thanks in advance.
Correct Answer by Brandon Buffin about 6 years 4 months ago
The following link has a good example of how to do this.
Hope this helps.
Overall Rating: 5 (1 ratings)
Md. Mijanur Rahman Thu, 06/03/2010 - 11:11
Hi, create a voip dial peer for your phone calls and a pots dial-peer for FAX like below:
dial-peer voice 1 voip
session protocol sipv2
session target ipv4:
no vad
Hope your phones are already registered as SIP and your voice register global is configured.
I haven't configure the FAX port yet but it's pretty simple as FXO port configuration, you will need a pots dial-peer for that.
dial-peer voice 2 pots
You might need some additional commands to active FAX protocol (as example:T.38), please google for it.
DIEGO ALONSO Thu, 06/03/2010 - 11:43
That's not quite what I mean.  The problem is for outbound calls.  I will have two dial peers with the same destination pattern.  For instance 9[2-9].......
The difference is one will be a Voip SIP port and the other an analog port.  So outbound calls made from a SCCP phone need to use the SIP trunk and when a FAX device places a call I need the CME to send it out on an analog port instead of the SIP peer.
So somehow I need the CME to match an outbound peer depending on which inbound peer is placing the call.
