BGP issues
Jun 3rd, 2010
I have two issues. i am running two router using bgp on hotstandby. One router is the primary on one is the backup. the issue are,
1) BGP is not passing the default route
2)  Getting BGP identifier wrong
I would I appreciate any help.
Here is the configuration of the router,
Main router
interface GigabitEthernet0/0
description Internal Network
ip address x.x.41.2 255.255.255.0
duplex auto
speed auto
media-type rj45
standby 1 ip x.x.41.1
standby 1 preempt delay minimum 60
standby 1 track Serial1/0
no mop enabled
router bgp 65000
no synchronization
bgp log-neighbor-changes
network x.x.41.0
redistribute connected
redistribute static
neighbor x.x.41.3 remote-as 65000
neighbor x.x.41.3 next-hop-self
neighbor x.x.188.77 remote-as 209
neighbor x.x.188.77 send-community
neighbor x.x.188.77 default-originate
neighbor x.x.188.77 route-map setpath out
neighbor x.x.22.229 remote-as 209
neighbor x.x.22.229 send-community
neighbor x.x.22.229 default-originate
neighbor x.x.22.229 route-map Swales out
no auto-summary
ip route 0.0.0.0 0.0.0.0  x.x.41.5
ip route x.x.222.0 255.255.255.0 x.x.41.5
Backup router
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address x.x.41.3 255.255.255.0
duplex full
speed auto
media-type rj45
no mop enabled
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
router bgp 65000
no synchronization
network x.x.41.0
redistribute static
neighbor x.x.41.2 remote-as 65000
neighbor x.x.41.2 next-hop-self
no auto-summary
Jose' Luis Granda
Giuseppe Larosa Thu, 06/03/2010 - 11:40
Hello Josè,
bgp router-id can be configured with
router bgp 65000
bgp router-id x.x.x.x
post the route-map configurations they may influence the capability to advertise a prefix including a default route
Hope to help
Giuseppe
jgranda12 Thu, 06/03/2010 - 12:15
Hello Giuseppe, Thanks for the quik response. Here is the router map
Main site for box units
route-map Swales permit 10
set community 13697114 13698023
route-map setpath permit 10
set community 13697094 13697114 13698023
Let me know if you need anything else.
Jose' luis Granda
