Password for BWT pages
Answered Question
Jun 3rd, 2010
Why is there no authentication on the BWT pages?  Isn't that a huge security hole?
Correct Answer by mcwalter about 6 years 7 months ago
I believe this doc will help you lock down the BWT side of the server. You may want to look for an updated version since this is for 6.1/4.1 installs.
Good luck
Overall Rating: 5 (1 ratings)
Correct Answer
mcwalter Thu, 06/03/2010 - 19:44
Good luck
derrickmunro Wed, 07/14/2010 - 07:45
In SUSE navigate to the vsmc.conf file located here: /usr/BWhttp/conf/http.d/
Just add this to the end
        AuthName "Cisco Media Server BWT Pages"
        AuthType Basic
        AuthUserFile /usr/BWhttpd/etc/.htpasswd
        Require valid-user
Using command line you can type:
vi /usr/BWhttp/conf/http.d/vsmc.conf
# pressing "i" puts you into "insert mode"
i
# Add the directory at the end
        AuthType Basic
        Require valid-user
# press esc then ":wq" and hit enter.
:wq
