Telnet timeout while VPN connected via ASA 5520
Jun 3rd, 2010
Hello Community;
When users are VPN connected their telnet sessions timeout after an hour of inactivity. Looking at the connections on the firewall they are showing as idle. Is there a configuration change or something else that has to be modified?
Any help will be greatly appreciated?
Thank You
Federico Coto F... Thu, 06/03/2010 - 15:54
  • Green, 3000 points or more
The tunnel never goes down? Is just telnet after an hour?
If the telnet connection is to the ASA itself, check the command:  sh run telnet (telnet timeout 60)
If it's telnet to an inside device, check the command:  sh run timeout
It might show you the connection timeout set to 1 hour.
Hope it helps.
Federico.
Related Content
