Replacement for RVL200-AU
Jun 3rd, 2010
  • Cisco Employee,
Hi Team,
Need a recommended replacement for RVL200-AU. There's nothing in the EOS notice so wondering if you can help me on this. I can't find RVL200-EU in the AU Price List either.
Also can you please clarify that what is the significance of using -EU or -AU at end of the SKU?
Best Regards,
Sohaib
Sohaib Ahmed Mon, 06/07/2010 - 21:51
  • Cisco Employee,
Can anyone help me on this please?
Best Regards,
Sohaib
timridley Thu, 09/16/2010 - 23:34
Hi Sohaib,
What are the features of the RVL200 that are most important to you?
There have been a significant number of new Cisco Small Business products that have launched in the past 6 months and some of them may have the features you want.
Cheers,
Tim
riroe Mon, 09/20/2010 - 02:13
The 2 digit code after the Model number is the country code. This is used sometimes because of the power requirement
for that specific country. Like the previous post says there are a number of new Small Business Routers that have been introduced
and you may want to take a look at some of those to see if they will fit your needs.
THANKS
