MGCP Process hung - how to kill process?
Jun 3rd, 2010
          Hi All,
I did a no MGCP on a 3725 and its been about half an hour.
When I go back and do mcgp it says
r-fwvpn02-il#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
r-fwvpn02-il(config)#mgcp
%MGCP-SHUTTING-DOWN, Cannot restart MGCP until it is finished shutting down
Is there a way to kill this process?
This is on my WAN router so I dont want to reboot the box.
Thanks All!
Overall Rating: 4.9 (6 ratings)
David Hailey Sun, 06/06/2010 - 19:05
  • Purple, 4500 points or more
Unfortunately, I don't believe there is a way to kill a single process using PID in IOS.  I've heard debate on one side or the other but for MGCP, SCCP, etc...when they hang, the result (even after TAC case sometimes) is that a reboot is the workaround/fix.  Schedule some downtime and reboot is your best bet from my view.
Hailey
Alan Libbee Wed, 07/01/2015 - 16:38
There is no way I am aware to kill the process, but usually it is hanging because there are active mgcp ports off hook. If you do a sh voice port sum, look for off hook ports and go and make them admin down. I just had this happen to me, I shut down 2 ports that were off hook and mgcp shut down. Or of course, you can reload the router.
marcell.varga94 Wed, 10/05/2016 - 07:40
This actually worked for restarting the mgcp proccess without a router reload.
Thank you.
Aman Soi Mon, 07/06/2015 - 10:12
  • Cisco Designated VIP,
    2017 IP Telephony
Hi JB,
thanks for sharing the bug[+5]
I checked but this bug is not publicly available.
regds,
aman
Jitender Bhandari Mon, 07/06/2015 - 10:57
  • Cisco Employee,
Hi Aman,
it looks like the BUG was not documented correctly, i have pasted the content for details.
Symptoms: Once the mgcp command was shut down by
configuring the no mgcp, it cannot be
restarted by the mgcp command. The router has
to be reloaded to restart the mgcp command.
Conditions: This symptom has been observed when the
mgcp command was shut down by configuring the
no mgcp command.
Workaround: There is no workaround
JB
Aman Soi Tue, 07/07/2015 - 01:15
    2017 IP Telephony
thnaks for reply.
Is this any router IOS specific?
regds,
aman
Jitender Bhandari Tue, 07/07/2015 - 05:01
  • Cisco Employee,
Aman,
It was first reported in 12.X train, but i can see it been reported on higher versions also.
JB
Aman Soi Tue, 07/07/2015 - 19:12
    2017 IP Telephony
thanks for updates[+5]
regds,
aman
sk5525001 Wed, 10/07/2015 - 01:58
SDR_Lab(config)#mgcp
In this case, you have to look for any hung ports, make them admin down and then resetting MGCP will work
SDR_Lab(config)#no mgcp
Rgds,
Shridhar Kadolkar
