IP PHONES AND DHCP
Jun 3rd, 2010
I have a 2821 rtr serving up ip addresses to some 7961 phones all connected to a 3560-48 port switch and everything has been working great.
The other day the 3560-48 power module went out so no POE.
We can get the phones online with local power and the 3560-48 which is great.
However I decided to replace the 3560-48 with a 3560-24 from our offline stock instead of installing another 3560-48 since the 3560-48 is way more than this site needs.
The 3560-24 loaded up and when it is installed it comes online just fine.
I can telnet to it, ping from it to anywhere in our network, and it delivers POE to the phones.
Other than having fewer ports on the 3560-24 the config is the same and the IOS is the same as the 3560-48.
However the 7961 phones will not pickup an IP address when the 3560-24 is online.
When the 3560-48 is installed again and the phones are plugged into local power they pickup an address from the router just fine.
Any ideas?
Reza Sharifi Thu, 06/03/2010 - 17:51
  • Cisco Designated VIP,
    2017 LAN
Did you clear the config (write erase) on the 3560-24 completely and rebooted before loading the new config?
Reza
Ganesh Hariharan Thu, 06/03/2010 - 18:49
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Any ideas?
Check out the configuration are same for  DHCP in the new switch for ip phone.
Ganesh.H
glen.grant Fri, 06/04/2010 - 05:25
   Verify  port configs for each match  what was on the old model.  Portfast turned on ?
phretbored Fri, 06/04/2010 - 14:04
Yes I did a write erase before loading a fresh config in the 3560-24.
The rtr is acting as the dhcp server and the 3560-24 has a default route to the rtr and also a voice vlan configured.
Everything on the 3560-24 config is the same as the 3560-48 other than there being less ports.
We did line by line comparison of the configs and everything is the same.
I am going to reload a fresh config in the 3560-24 again and bring it online as a second switch and work with it that way.
