Logging Issue
Answered Question
Jun 3rd, 2010
Am always receiving up logs in one of my LAN interfaces. There are n
o interface downlods.
Wondering what could be the issue. Could there be a real link flap issue.
Why could the same link always come up without going down.
001391: Jun  4 09:51:58.850 INDIA: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
001392: Jun  4 12:01:19.930 INDIA: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
001393: Jun  4 12:01:25.438 INDIA: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
001394: Jun  4 12:02:43.599 INDIA: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
Any suggestions?
Thanks in advance.
AneesH
Correct Answer by Joe Clarke about 6 years 8 months ago
This could be CSCsv90092.  Is CEF disabled?  If so, enabling on this interface will work around the problem.  The bug is fixed in 12.4(15)T10.
Overall Rating: 5 (1 ratings)
aneesh.ts Sun, 06/06/2010 - 22:03
IOS & hardware details..
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(15)T9, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Tue 28-Apr-09 11:11 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
NS-CHN-DLN-R01-P uptime is 16 weeks, 6 days, 4 hours, 20 minutes
System restarted at 09:57:22 TOKYO Tue Feb 9 2010
System image file is "flash:c1841-ipbase-mz.124-15.T9.bin"
Cisco 1841 (revision 7.0) with 115712K/15360K bytes of memory.
Processor board ID FHK1327736Z
2 FastEthernet interfaces
1 Serial(sync/async) interface
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
AneesH
Correct Answer
Joe Clarke Sun, 06/06/2010 - 23:41
aneesh.ts Mon, 06/07/2010 - 00:04
Hi joe,
Thank you so much mate.
You were absolutely right. We've seen a lot of throttles as mentioned in the Bug description.
Unfortunately CEF is already enabled on the router. However I again enabled it on the interface.
Not sure whether it will help.
Lemme monitor the device for a while now. Since its not impacting, nothing much to worry.
You were so helpful and I totally appreciate your effort with this.
AneesH
