i want to use RTTMON MIBS for ICMP Latency
Jun 4th, 2010
I am using The Cisco 2811 Routers for Branch Officies and that use "ip sla" and EEM configuration for monitoring.
I find OID match Name and Stirng list.
is The following configuration true?
What can I use digit instead of rttMonLatestJitterOperOWMaxSD?
ip sla monitor 111
type echo protocol ipIcmpEcho x.x.x.x source-ipaddr y.y.y.y
request-data-size 1500
frequency 30
ip sla monitor schedule 111 life forever start-time now
event manager applet blabla
event snmp oid rttMonLatestJitterOperOWMaxSD.111 get-type exact entry-op eq entry-val 1 exit-op eq exit-val 2 poll-interval 5
action 1.0 syslog priority critical msg "BlaBla"
action 1.1 snmp-trap strdata "EEM detected BlaBla Latency"
Joe Clarke Fri, 06/04/2010 - 22:01
You will need to use a jitter operation to be able to use this object.  Right now you're just doing an ICMP echo.  For that, you could monitor rttMonLatestRttOperSense (  If the value is something other than 1, then an error occurred (e.g. the round-trip response time was over the threshold, a timeout occurred, etc.).
