Giuseppe Larosa Fri, 06/04/2010 - 04:46
  • Hall of Fame,
    Founding Member
Hello Egeorgopolus,
do
sh run | inc username
if you find a line like
username root
you just need to deny it with
conf t
! report the whole line here with no in front
no username root
Hope to help
Giuseppe
egeorgopoulos Fri, 06/04/2010 - 05:52
Actually there is no root username, so this username cannot be disabled. Any other clu
es?
Thank you.
hobbe Fri, 06/04/2010 - 06:18
  • Gold, 750 points or more
Do you have any AAA statements to a tacacs or radius server that could contain the user root ?
How do you know that root is logging in ?
If there for some reason now is a user root who loggs in at the router without password
First, have you tried to login with root ?
Second, why not create the user root with an very complex password ?
would that keep them out ? atleast until you can figure out whats going on ?
egeorgopoulos Fri, 06/04/2010 - 06:35
Yes, I tried with root user and it can log in without entering any password. The AAA is enabled, so for the time being I modified the root user to enter the system with a password.
The odd thing is that there wasn't any username 'root' in the configuration before. At least now, this user is forced to enter a password.
Thank you.
hobbe Fri, 06/04/2010 - 07:21
If you are using AAA you can use a user database outside the router. (radius/tacacs+)
If the AAA is enabled and you are using it, the root user gets his/her credentials from the AAA server.
So if the AAA server is a linux/unix style box, (most likely since windows does not use root) then most likely there is a problem with the root user at that machine, ie that root user does not have a password. (wich can be quite bad)
a local user database would have shown the username root in the config
(to check local database just do :  "sh ru | include root"  the | is the pipe sign.)
