new switch blades not powering on
Ryan Coverdale
New blades (module 11 and 13) are recognized by the system, but not powering on. See Below:
trd651301#sho mod
Mod Ports Card Type                              Model              Serial No.
  1   48  SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX     SAL1114KR8C
  2    5  Communication Media Module             WS-SVC-CMM         SAD110204XX
  3   48  48-port 10/100 RJ45 Ethernet Module    WS-X6148A-45AF     SAL1115LCJL
  4   48  48-port 10/100 RJ45 Ethernet Module    WS-X6148A-45AF     SAL1115LN2U
  5   48  48-port 10/100 RJ45 Ethernet Module    WS-X6148A-45AF     SAL1115LCJN
  6   48  48-port 10/100 RJ45 Ethernet Module    WS-X6148A-45AF     SAL1115LMDC
  7    9  Supervisor Engine 32 8GE (Active)      WS-SUP32-GE-3B     SAL1120P0E3
  8    0  Unknown (Other)                        Unknown            Unknown
  9   48  48-port 10/100 RJ45 Ethernet Module    WS-X6148A-45AF     SAL1115LMG3
10   48  48-port 10/100 RJ45 Ethernet Module    WS-X6148A-45AF     SAL1115LCL4
11   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1419HJJ8
13   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1419HJKY
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  001b.2a8b.40c8 to 001b.2a8b.40f7  11.1   7.2(1)       t_whit21@1.0 Ok
  2  0019.e828.f91e to 0019.e828.f927   2.9   12.4(16),    12.4(16),    Ok
  3  001b.54ae.5a60 to 001b.54ae.5a8f   4.3   8.4(1)       t_whit21@1.0 Ok
  4  001b.5480.7d60 to 001b.5480.7d8f   4.3   8.4(1)       t_whit21@1.0 Ok
  5  001b.54ae.4f20 to 001b.54ae.4f4f   4.3   8.4(1)       t_whit21@1.0 Ok
  6  001b.5480.8060 to 001b.5480.808f   4.3   8.4(1)       t_whit21@1.0 Ok
  7  001a.6d1a.e842 to 001a.6d1a.e84d   4.5   12.2(18r)SX2 12.2(33)SXI1 Ok
  8  0000.0000.0000 to 0000.0000.0000   0.0   Unknown      Unknown      Unknown
  9  001b.5480.79d0 to 001b.5480.79ff   4.3   8.4(1)       t_whit21@1.0 Ok
10  001b.5480.3710 to 001b.5480.373f   4.3   8.4(1)       t_whit21@1.0 Ok
11  5475.d06f.e4c0 to 5475.d06f.e4ef   3.4   Unknown      Unknown      PwrDown
13  5475.d06f.e2b0 to 5475.d06f.e2df   3.4   Unknown      Unknown      PwrDown
Mod  Sub-Module                  Model              Serial       Hw     Status
2/1 6-Port T1 Interface         WS-SVC-CMM-6T1     SAD110406LD  2.3    Ok
2/2 6-Port T1 Interface         WS-SVC-CMM-6T1     SAD11070148  2.3    Ok
  3  IEEE Voice Daughter Card    WS-F6K-48-AF       SAL1114KV5L  2.3    Ok
  4  IEEE Voice Daughter Card    WS-F6K-48-AF       SAL1115LN4F  2.3    Ok
  5  IEEE Voice Daughter Card    WS-F6K-48-AF       SAL1115LB6C  2.3    Ok
  6  IEEE Voice Daughter Card    WS-F6K-48-AF       SAL1115L7H8  2.3    Ok
  7  Policy Feature Card 3       WS-F6K-PFC3B       SAL1120P0GU  2.3    Ok
  7  Cat6k MSFC 2A daughterboard WS-F6K-MSFC2A      SAL1120P028  4.0    Ok
  9  IEEE Voice Daughter Card    WS-F6K-48-AF       SAL1115LN68  2.3    Ok
10  IEEE Voice Daughter Card    WS-F6K-48-AF       SAL1115LB65  2.3    Ok
11  Centralized Forwarding Card WS-F6700-CFC       SAL1417GJWC  4.1    PwrDown
13  Centralized Forwarding Card WS-F6700-CFC       SAL1417GHWK  4.1    PwrDown
Mod  Online Diag Status
  1  Bypass
  2  Bypass
  3  Bypass
  4  Bypass
  5  Bypass
  6  Bypass
  7  Bypass
  8  Not Applicable
  9  Bypass
10  Bypass
11  Not Applicable
13  Not Applicable
trd651301#sho  power status module 11
                        Pwr-Requested  Pwr-Allocated  Admin Oper
Slot Card-Type          Watts   A @42V Watts   A @42V State State
11   WS-X6748-GE-TX      325.50  7.75     -     -     on    off (Fabric required)
trd651301#sho  power status module 13
13   WS-X6748-GE-TX      325.50  7.75     -     -     on    off (Fabric required)
trd651301#
Any ideas?
attached is the sho ver.
2 Accepted Solutions
Giuseppe Larosa
Hello Ryan,
these 6748 linecards are supported only when using sup720 you have a sup32!
so they are powered off because they cannot talk to other modules without a sup720 with its built-in 720 Gbps switching fabric
remove them from this chassis you cannot use them in it unless you change supervisor
sup32 has only the 32 Gbps shared bus no switching fabric
see
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps5972/product_data_sheet0900aecd801c5cab_ps708_Products_Data_Sheet.html
Hope to help
Giuseppe
Leo Laohoo
It's because you have a Sup32.
WS-X6748-GE-TX requires Sup720.
Reza Sharifi
Hi Ryan,
Do you have a big enough power supply to light up all the module?
Reza
Giuseppe Larosa
Hello Ryan,
see
Hope to help
Giuseppe
Leo Laohoo
Leo Laohoo
Thanks for the ratings.
