Cisco 867 (Annex A) - 8 IPs, 10 VLANS with Trunk to 2960
Jun 4th, 2010
is it possible to bind 6 public IPs to the ADSL interface from the CISCO 867 (one IP per VLAN), that every VLAN has his own public IP?
So that i can NAT every Subnet/VLAN to the specific public IP.
The PCs are connected on the 2960 and they'll speak over the TrunkPort connected between Cisco867-----TRUNK-----Cisco2960
What are the max VLANS on the Cisco 867?
Are there NAT transl. Limits?
thx Konrad
Hitesh Vinzoda Fri, 06/04/2010 - 07:31
Though information on Cisco doesnt explicitly says support for number of Vlans, it should be 0-4095, you may try creating vlan with #vlan ? you will get the number of vlan's supported. also you can perform NAT on this box, not an issue
You can create 8 different pools with 8 single IP addresses and allote pool to specific subnet.
here is the example to configure NAT on 867 box.
Hitesh Vinzoda
Pls rate useful posts
LBS-BZ-HI Sat, 06/05/2010 - 05:03
hi kmccourt,
thanks, you are right! these models only supports 2 VLANs, so i have to get the 1900Series with ADSL Interface?
Have you an other Router suggestion?
kmccourt Sat, 06/05/2010 - 05:07
The 887 supports 8 VLANs.
(Edit). Sorry - I forgot you wanted 10 VLANs. I suppose another option would be an 1841 with ADSL HWIC.
LBS-BZ-HI Sat, 06/05/2010 - 05:35
ok, i think the 1841 with hwic ADSL2 module (CISCO1841-ADSL2) is my solution.
do you know if in the broadband image from the broadbandbundle, the Firewall is included or i have to buy the CISCO1841-SEC/K9 image?
Related Content
