2nd Hop transfers
Software Version: CUCM 4.2(3)sr4a
2 Gateways MGCP
This is the scenario.
A call comes from outside of the organization to 76xx to CTI to a receptionist 47xxx. Then call is transferred to the bosses receptionist at DID 7665. Then the bosses receptionist tries to transfer to the boss at DID 7612. The call is dropped and the original caller gets a message from our PRI provider AT&T (all circuits are busy).
This scenario has been tried with many different phones in the same location with the same results.
Further information as follows:
This situation may have been going on since the original Cisco CM install (not sure)
The configuration may have been designed this way to prevent toll fraud
This is a Secured Facility
All internal transfers work flawlessly
1st Hop transfers work fine for example, calls from the outside to bosses receptionist and then to the boss work just fine.
Bosses receptionist phone has been replace with a new one as a precaution
Other thoughts:
Could this be a mismatch in CSS on the involved phones?
Could this be a device pool issue?
Could this be a dial plan issue?
Could this be a Route Pattern issue?
Could this be a Gateway issue?
Does this scenario sound familiar to anyone?
Any thoughts or observations will be appreciated
Overall Rating: 5 (1 ratings)
Rob Huffman Fri, 06/04/2010 - 12:59
Hi Tom,
That is a "strange" one for sure. Just for testing purposes
can you check this parameter in CUCM;
Set the Block OffNet to OffNet Transfer  clusterwide
service parameter to False and try the test again.
Cheers!
Rob
Rob,
I thought I owed you an update on this. You have helped me out several times in the past.
It turns out all this maybe due to an ISDN protocol mis-match.
DMS-100 versus the NI2 protocol.
The original CM installers used the DMS-100 protocol on the Cisco 2851 Gateway because they said the NI2 protocol did not work and would not allow calls through.
What makes matters worse on the Provider side ATT they are using the NI2 protocol.
I am going to make the change and see what happens. Also, here is a TRACE I preformed on the Gateway during a test call.
Best Regards, Tom
Rob Huffman Thu, 06/17/2010 - 08:53
Hey Tom,
Thanks for posting back my friend +5 for sharing this update.
This makes sense, and I'm kind of surprised other things don't work
properly with this protocol mis-match. We use DMS100 on our gateways
and our telco uses DMS100 from their end as well. The testing I did when
you first posted up this issue did not produce any problems with the 2nd hop
Transfer in any way.
Cheers!
Rob
