06-04-2010 08:45 AM - edited 03-15-2019 11:06 PM
We have Unity Connection Ver 7.1.3. The default web admin page port number is 443 and/or 8443. is there a way to change the port number? if so, can I change the Admin page to say 543 and the CiscoPCA page to 643?
Thanks.
Mark
Solved! Go to Solution.
06-04-2010 06:03 PM
You cannot modify anything related to the tomcat server which handles the GUI pages, this means you cannot change the ports used.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
06-04-2010 09:37 AM
I don't know of a facility to do this and; in any case, it would require that you be knowledgeable of which ports are used by the application as a whole and for what before changes are made. See here for details:
www.cisco.com/application/pdf/paws/110172/cuc-netports.pdf
Hailey
Please rate helpful posts!
06-04-2010 06:03 PM
java
