Cisco Unified Communications Manager TSP
I am trying to create a new Windows 7 64bit image.  Currently my Windows XP image has has Cisco Unified Communications Manager TSP 6.1.3  which is also of course the same train as my CUCM version 6.1.3.
Is there a compatible Cisco Unified Communications Manager TSP version for Windows 7 64bit that will work with CUCM version 6.1.3?
htluo Fri, 06/04/2010 - 09:31
As far as I know, TSP will support 64-bit OS in version 8.5 (due Q4 2010).
You may try ealier versions.  But there's no guarantee and support from Cisco.
kristyorr Wed, 11/17/2010 - 14:20
I spent time researching this as well.  Previous post is correct, not until Q4 2010.
Here a link is the compatibility matrix:
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
