Cisco 7301 Router Bootflash
Jun 4th, 2010
The disk0: from which the router boots from went bad (unable to read the flash card with the image).  There is the bootflash: where the bootloader is stored.  The router is in boot mode router (boot)#
I was able to transfer an image to the bootflash: and change the boot variable but the router did not reload properly.
Is the bootflash: not able to read and load the ios image ?  Is it only for the bootloader ?
Pete
Overall Rating: 2 (1 ratings)
Giuseppe Larosa Fri, 06/04/2010 - 14:07
  • Hall of Fame,
    Founding Member
Hello Pete,
post
show bootvar
dir bootflash:
you need a line like
boot system flash bootflash:iosfilename
or
boot system bootflash:iosfilename
you can check with
dir bootflash:
or
dir bootflash:iosfilename
Hope to help
Giuseppe
xayavongp Mon, 06/07/2010 - 07:29
It appears the problems affecting disk0: is causing issues with the system bus. I was able to barely see it and it crash again.
Thanks for your input.
Related Content
