6509 - MEM-MSFC3-1GB upgrade
Answered Question
Jun 4th, 2010
under which criteria should I do this upgrade (MEM-MSFC3-1GB) for a sup720?
Correct Answer by Reza Sharifi about 6 years 12 months ago
According to memory guidance for 6500 series;
Upgrade Considerations for memory:
(1) Large route tables >25k entries
(2) Premium features (for example, enhanced Fast Software Upgrade [eFSU], In-Service Software Upgrade [ISSU])
(3) Right size memory now for future Cisco IOS Software images on Cisco Catalyst 6500/Cisco 7600 Series Supervisor Engine 720 Cisco Catalyst 6500 Supervisor Engine 32 and ME6524
Here is more info:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/qa_c67_457347.html
Reza
Correct Answer by belovell about 6 years 12 months ago
This would be needed for something along the lines of "I have 512MB of RAM and I am low or out of memery when I activate all my BGP peers". Each full internet table will take very roughly 230MB. Upgrading to 1GB of memory on the MSFC will allow you to hold a bigger BGP table.
Be warned, this will NOT increase the number of routes that can be programed into TCAM for hardware forwarding. This is memory for the RP only.
-Ben
Overall Rating: 5 (2 ratings)
Correct Answer
belovell Fri, 06/04/2010 - 10:19
-Ben
Correct Answer
Reza Sharifi Fri, 06/04/2010 - 14:17
  • Cisco Designated VIP,
    2017 LAN
Here is more info:
Reza
belovell Sat, 06/05/2010 - 10:23
rafaeljimenez wrote:
Hellos Ben,
What about MEM-SUP720-SP-1GB?.
Later..
That would be the memory upgrade for the switch processor on the SUP to 1GB.
-Ben
nhatnd1988 Mon, 09/23/2013 - 20:35
Hi all,
Now I have Router 7613 with SUP
WS-Sup720-3BXL. Can I use DRAM ( 1GB) include SP and RP to change DRAM on 7609. I want to upgrade SP and RP RAM on 7609 from 512M to 1G.
