Switch Configuration Recommendations for Small Home Network
Jun 4th, 2010
I have recently purchased a used Cisco Catalyst 3512XL switch (12.0 firmware) for a small home network (~3 PCs, 2 printers, server with GbE NIC, WAP). I currently have the default settings, but I want to take advantage of all the functions that the firmware offers that would be relevant to such a network; i.e., user accounting would be useless, but storm control might be useful in case of a host on the network becoming compromised with malware causing a broadcast flood.
Any suggestions? Thanks in advance.
Leo Laohoo Fri, 06/04/2010 - 22:29
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
I'd be careful using 3500XL with modern or latest generation of Gig NICs.  I was involved with a multi-million dollar project to roll out new PCs with Gig cards (Intel).  I was with the network team and we noticed that there are some cases where the ports would just flap like mad!  We managed to fix by hard-coding speed and duplex.
Enable spanning-tree portfast and BPDU guard would be good.  Storm control on a XL switch?  Never thought that it was supported but I could be wrong.  Regularly clean the fan blades because the accumulation of compressed dusts all over the fans can strain the bearings.  The accumulated dusts plus a very weak bearing can be very noisy plus can cause the bearings to fail.
mbroberson1 Sat, 06/05/2010 - 04:04
I would consider just picking up a used 3550/24 if its just for a small home network. The 3550 will do everything you want then some. If space is an issue and you want a switch a little smaller then consider the 2490 switch, it is an 8 port switch you can sit on a pc and will also run all nessesary features.
Please rate if posting help.
Kind Regards
Related Content
