Regarding configuration changes reports in LMS 2.5
Jun 4th, 2010
I am having LMS 2.5 installed.
I want step by step configuration for generating report of
configuration changes made on devices.
I have tried with change audit plus syslog but unable to generate report.
What i need is mail should be sent on configuration changes of critical devices
plus 24-hour report of same for network changes.
Please let me know steps and commands on routers and on LMS 2.5
Vaishali
Please follow up below link for LMS2.5 inatllation and configuration.
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/2.5/quickstart/guide/lms25qsg.html
Set up notifications: In addition to watching network conditions as they change on the Alerts and Activities display, you can use DFM
notification services to automatically notify users and other systems when specific changes occur on selected devices.
You must create subscriptions for e-mail notifications, DFM-generated SNMP trap notifications, or Syslog notifications.
You can perform this task from LMS Portal using Device Fault Manager >Notification Services in the Notification Services page.
You can also change event names to names that are more meaningful to you,and these names will appear in theDFM displays and notifications.
I feel this will helpful to you!!!
Thanks & Regards,
Venkat
