SPA525G VPN Timeout
SHANE FREESE
I have successfully gotten the SPA525G to connect to my ASA 5510 via SSL VPN.  However it seems to be idle disconnecting.  I've disabled idle disconnect in the VPN Group Policy but that didn't do the trick.  Is there something on the phone I need to set so it won't idle disconnect?
SHANE FREESE
Guess no one has experienced this, I've tried everything but still the phone's vpn connection times out after 30 mins or so.  Timeout is disabled on the ASA so I'm not sure what the problem is.
Hello. We've exactly the same problem. Did you find already a solution for this problem?
Thanks a lot!
Yes.  You can't just disable idle disconnect in the ASA.  You have to set the timeout value to something high.  I used the max.
