06-04-2010 12:09 PM - edited 07-03-2021 06:51 PM
Hi folks.
I usually work with controllers, so am getting a bit caught with what should be simple but seems not to be. I have 2 x 1131 autonomous. I have VLAN 1 (Native), VLAN 10 and VLAN 20. I would like to broadcast SSID 10 on VLAN 10 and broadcast SSID 20 on VLAN 20, and have both with WPA2 PSK. However as I configure 1 SSID, it overwrites the settings of the other, and I haven't even got to adding WPA2 yet.
Can someone give me some simple pointers ?
Thanks.
06-05-2010 07:14 AM
Hard to say without seeing exactly what you are doing when you are trying to configure the AP. Here is a doc on working with VLANs on aIOS APs:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080665ceb.shtml
Can you post the config? Also, if you want to broadcast multiple SSIDs with IOS based APs, you have to use the mbssid command:
dot11 ssid VLAN1
vlan 1
authen open
authen key wpa
wpa ascii 0 87654321
mbssid guest
dot11 ssid VLAN20
vlan 20
authen open
authen key wpa
wpa ascii 0 12345678
mbssid guest
int dot0
encrypt vlan 1 mode ciphers aes
encrypt vlan 20 mode ciphers aes
mbssid
Lee
06-08-2010 10:15 AM
Hi there,
As lee said, you will need to issue the command MBSSID to activate multiple SSID support. Also, when you create more than SSID you will have to issue the command guest-mode under SSID configuration mode to enable SSID broadcasting, if not your SSID can be created working and usable but not listed in the available wireless networks list.
