Problem charging IOS in SUP-720
Jun 4th, 2010
Dear Mister
I charged a IOS version in the sup-bootdisk in my Supervisor ws-720-3b.
I have two IOS:
Router#dir sup-bootflash:
Directory of sup-bootdisk:/
    1  -rw-    78859268  Nov 20 2009 14:21:58 +00:00  s72033-ipservices_wan-mz.122-18.SXF17.bin
    2  -rw-   116284484   Jun 4 2010 19:40:34 +00:00  c7600s72033-adventerprisek9-mz.122-33.SRC6.bin
512024576 bytes total (316874752 bytes free)
When I start the module with 12.2(18)SXF17 the equipment start OK. But when I start with the 12.2(33)SRC6, the console show the next:
Initializing ATA monitor library...
loadprog: error - on read during ELF program load
requested 124971540 (0x772ea14) bytes, got 116250184 (0x6edd648)
boot: cannot load "bootflash:c7600s72033-adventerprisek9-mz.122-33.SRC6.bin"
Exit at the end of BOOT string
rommon 1 >
rommon 1 > dir bootflash:
Directory of bootflash:
2      78859268  -rw-     s72033-ipservices_wan-mz.122-18.SXF17.bin
9629    116284484 -rw-     c7600s72033-adventerprisek9-mz.122-33.SRC6.bin
rommon 2 > boot bootflash:s72033-ipservices_wan-mz.122-18.SXF17.bin
Loading image, please wait ...
And started OK.
Questions:
What is the reason for this? The memory is 512 MB RAM, sup-bootdisk has 512 MB.
I am searching in Cisco Web one explanation about it, but I still haven´t found.
Best Regards
rodrigo.hernandez Fri, 06/04/2010 - 15:33
Francisco
This equipments is a 7600:
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICES_WAN-M), Version 12.2(18)SXF17, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by cisco Systems, Inc.
Compiled Fri 25-Sep-09 10:42 by ccai
Image text-base: 0x40101040, data-base: 0x42ABEB70
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-IPSERVICES_WAN-M), Version 12.2(18)SXF17, RELEASE SOFTWARE (fc1)
Router uptime is 12 minutes
Time since Router switched to active is 11 minutes
System returned to ROM by s/w reset at @bT^TDc# Dc# P?^_p (SP by power-on)
System image file is "sup-bootdisk:s72033-ipservices_wan-mz.122-18.SXF17.bin"
cisco CISCO7609 (R7000) processor (revision 1.1) with 458720K/65536K bytes of memory.
Processor board ID FOX0911071H
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
SuperLAT software (copyright 1990 by Meridian Technology Corp).
--More--                           X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
1 Virtual Ethernet/IEEE 802.3 interface
48 FastEthernet/IEEE 802.3 interfaces
2 Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Router#
Router#
Thanks, but I think that the problem is other.
francisco_1 Sat, 06/05/2010 - 13:56
Dont know why i thought you are using cat 6500. My apologies.
Your IOS might be corrupted!!!!. Try to download it again.
Francisco.
rahurao Fri, 06/04/2010 - 16:31
Hi Rodrigo,
I checked the same and seems like it is corrupt image and that is causing the sup to go down in ROMMON.
Rahul
