Huntgroup/CTI Route/Call Handler
Answered Question
Jun 4th, 2010
Current setup:
DID (6370) -> CTI Route (x6370) transfers to Call handler -> Call Handler (x6370), makes an announcement -> Hunt Polit (50000)
What i want to do:
After the hunt polit is no answer to go to a voice mail account x2370. I tried to configure the Hunt Forward Setings. It there is an extension, does not matter the extension, goes to a general announcement. if there is not extension in the forward setting, fast busy signal.
Note: the extension x2370 is not assigned to a phone, but a cti route. cti routes cannot be added to the list group.
Correct Answer by Rob Huffman about 7 years 3 weeks ago
Hi Nicholas,
The Forward setting should go the Voicemail Pilot#. You need to try and
find out what the VM system is seeing as the CLID that is being passed as the
final number. I'm guessing it will be 5000. If this is the case you would set up 5000
as an Alternate extension under 2370 and you would be good to go
If you let us know what system you are using for VM we can help you find out
the CLID that is being passed along.
Cheers!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Fri, 06/04/2010 - 17:22
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Nicholas,
Cheers!
Rob
Nicholas Wysocki Sun, 06/06/2010 - 17:19
I am used to other phone systems. the cisco allowed the use of more then 4 digits as an extension but would only pass along 4 digits to the voice mail. 50000 was being translated to 0000. I changed the range of my hunt groups to 4000's and now the voice mail is seeing the correct calling number.
