Possible to rotate my PVC2300 image without turn my camera?
Steven DiStefano Sat, 06/05/2010 - 03:58
  • Blue, 1500 points or more
The PVC300 has a "flip video" button you can check as it must be physically turned over to mount on a flat durface (desk or ceiling), which is what you may remember seeing in documentation or discussed on the forum.
The xVC2300 you will notice has a threaded hold on the top and one on the bottom.  The top one usually has a black plug in it, so its hiding :-)
If you attach the camera to a ceiling mount, just use the top threaded hole, and the camera remains right side up.
Kind of a mechanical solution, which I hope helps you.
Related Content
