T-CCS source IP address
Jun 5th, 2010
Hi, we use T-CCS over an MPLS circuit to connect two legacy PBX's together. I need to change the source IP address that the router automatically picks.
Is there a way to do this? I can't find one.
Paolo Bevilacqua Sat, 06/05/2010 - 16:23
Are you using SIP or H323 ?
Note, it's quite unlikely you need T-CCS, even with legacy PBXs.
jeremy.t Wed, 06/09/2010 - 04:54
Thanks for your response. I found I didn't actually need to specify the source IP in the end, it picked the correct one anyway. But I'd be interested to know what other options there are for connecting legacy PBX's running DPNSS.
bhough Thu, 03/24/2011 - 12:59
got it to work with TCCS, but our d-channel on the pbx's is failing intermittently.
do you have a sip example config, or any ideas on where to check for Tccs issues with my d-channel?
funny thing, when we have a call up and the pbx throws a trap that the d-channel dropped our call quality is not affected.
brad
