Etherchannel error
Jun 5th, 2010
Hi folks,
running CAT 6513, IOS v12.2(33) (sxh)
created 2 trunks interfaces and attempted to add them to an etherchannel.  One of the interfaces continued to drop into an up/down(not connected) state with the following error in the log:
Jun  4 16:54:51: %EC-SP-5-CANNOT_BUNDLE2: Gi8/35 is not compatible with Gi4/28 and will be suspended (flow control send of Gi8/35 is on, Gi4/28 is off.
So, i disabled send flowcontrol on 8/35.  This allowed me to add to the EC, but i later looked at this interface and found it to be negotiating at 100mb full rather than 1gb full.
The EC is being used to trunk multiple vlans to a VMWare ESX host.  I thought possibly the NIC on the host was causing the problem, but found it to be set to auto-negotiate.
Any thoughts on this?
thanks.
Bruce
joealbergo Sat, 06/05/2010 - 12:52
I am a noob but I still wanted to ask you this:
Did you try turning flow control on both ends? Instead of having them both turned off?
Also, is there anyway you could be running different cables to the devices that are causing the incompatibility?
I hope you get this resolved. Let me know.
joealbergo Mon, 06/07/2010 - 12:52
I'm hoping the originator of the thread will come back to let us know what happened
Bruce Summers Mon, 06/07/2010 - 14:34
well,
so far, it hasnt worked...I set the both switch interfaces (in my case 4/28 and 8/35) Send flow control to on, and when I added the second interface in the EC, it errored with a slightly different error stating that the first interface (4/28) flowcontrol status is "disagree".
so far, no resolution...
bruce
joealbergo Mon, 06/07/2010 - 14:42
Bruce
Is Auto-negotiation on the port enabled or disabled?
Enable it on both ports and use the sync-restart-delay command.
Just offering suggestions here.
Joe
