Dual Broadband connection with 1841 ?
Jun 6th, 2010
Hi ,
i have have two broadband connections(PPPOE)(RJ45) for my office  and i want to know if there is a way i can Bundle them or load balance these lines on 1841router or any other router.please advise.
Laurent Aubert Sun, 06/06/2010 - 10:08
Bundling several PPPoE links does work but it's not officially supported (please contact your local account team to have lattest info about the roadmap).
The main restriction is to use a single ISP for all the connection which support this feature as well so you need to contact it.
A simpler solution is to do cef load-balancing by configuring two different dialer interfaces (one per link) and having two default routes in the routing table.
Laurent.
