Email alert on asa for successful login to asa
Answered Question
Jun 6th, 2010
Hi guys,
Just wanted to know how to configure the asa with email alerts for successful login to asa using telnet or asdm.
Jvalin
Correct Answer by Marcin Latosiewicz about 6 years 9 months ago
I don't see logging list assigned to logging mail.
logging mail list NAME_OF_LIST
Jvalin,
I assume you have everything but logging component configured.
How about creating a logging list of interesting syslogs and sending them?
http://www.cisco.com/en/US/docs/security/asa/asa82/command/reference/l2.html#wp1772936
http://www.cisco.com/en/US/docs/security/asa/asa82/command/reference/l2.html#wp1773126
Messages indexed:
https://www.cisco.com/en/US/docs/security/asa/asa82/system/message/logmsgs.html
maybe:
710002
Marcin
Overall Rating: 5 (1 ratings)
Correct Answer
Marcin Latosiewicz Sun, 06/06/2010 - 04:11
  • Cisco Employee,
Jvalin,
Messages indexed:
maybe:
710002
Marcin
jvalin__s Sun, 06/06/2010 - 04:38
Marcin,
Thanks for the links,I checked all those but still the mails are not working
what I did in ASDM is
1) setup the SMTP server - "internal ip address of ther mail-server"
2)configured "send from email address"
3) configured "send to email address"
4) configured "event-list" --> event-class as auth and severity - alert
                    "event-list --> event-class as config and severity - alert
5)  configured "logging filters and in the email section i gave the event-list as the severity
Any thing else am I forgetting?
Jvalin
Marcin Latosiewicz Sun, 06/06/2010 - 04:56
  • Cisco Employee,
Jvalin,
Can you rather show the CLI config? No access to ASDM on my side.
show run logg
show run smtp-s (or maybe show run smtp?)
Marcin
Kureli Sankar Sun, 06/06/2010 - 05:21
  • Cisco Employee,
I remember an earlier thread that I answered a while ago. It ended up being the e-mail server not accepting e-mails from the firewall's IP address.
Pls. make sure the e-mail server is configured to accept e-mail from the firewall's IP address.
Wireshark capture on the e-mail server will be useful as well.
Just move one of the normal messages like 111008 to level 1 for testing purpose only and issue a "write mem" that should trigger an e-mail to be sent.
loggin message 111008 level 1
Once the test is done you can remove the above line.
-KS
jvalin__s Sun, 06/06/2010 - 05:41
logging enable
logging timestamp
logging list email-for-login level emergencies class auth
logging list email-for-login level emergencies class config
logging list email-for-login message 111008
logging history informational
logging asdm informational
logging recipient-address [email protected]
level emergencies
logging facility 23
logging debug-trace
logging class auth mail alerts
logging class config mail alerts
logging message 111008 level alerts
Is this ok guys??
jvalin__s Sun, 06/06/2010 - 05:50
asa5510# sh run smtp-server
smtp-server 192.168.102.50
asa5510#
Correct Answer
Marcin Latosiewicz Sun, 06/06/2010 - 06:39
  • Cisco Employee,
jvalin__s Sun, 06/06/2010 - 06:44
logging enable
logging timestamp
logging list email-for-login level alerts class auth
logging list email-for-login level alerts class config
logging mail email-for-login----------------------------------------->>>i gave it afterwards
logging from-address abc@xxx.com
logging recipient-address abc@xxx.com level alerts
logging facility 23
logging debug-trace
Its working now guys Thanks to both of you.
jvalin__s Sun, 06/06/2010 - 06:51
Guys,
By configuring these commands,
I am getting alerts only when anybody configures using ASDM,
but not by command line.
Any ideas greatly appreciated.
Jvalin
Marcin Latosiewicz Sun, 06/06/2010 - 07:31
  • Cisco Employee,
710002 would the message you're looking forward when someone logs in.  I'd have to dig in a bit more to see what ASDM puts in syslogs. Or you can check it by monitoring logging to other facilities.
Kureli Sankar Sun, 06/06/2010 - 10:58
  • Cisco Employee,
Are you looking for these messages?
When you ssh to the unit you see the following:
Jun 06 2010 13:03:07: %ASA-6-605005: Login permitted from 10.117.14.66/56023 to 172-net:172.18.254.34/ssh for user "cisco"
Jun 06 2010 13:03:09: %ASA-6-113012: AAA user authentication Successful : local database : user = cisco
Jun 06 2010 13:03:09: %ASA-6-113008: AAA transaction status ACCEPT : user = cisco
Jun 06 2010 13:03:09: %ASA-6-611101: User authentication succeeded: Uname: cisco
Jun 06 2010 13:03:09: %ASA-5-502103: User priv level changed: Uname: cisco From: 1 To: 15
Jun 06 2010 13:03:09: %ASA-5-111008: User 'cisco' executed the 'enable' command.
When you telnet to the unit you see the following.
Jun 06 2010 13:04:16: %ASA-6-605005: Login permitted from 192.168.2.2/1308 to inside:192.168.2.1/telnet for user ""
Jun 06 2010 13:04:20: %ASA-6-113012: AAA user authentication Successful : local database : user = cisco
Jun 06 2010 13:04:20: %ASA-6-113008: AAA transaction status ACCEPT : user = cisco
Jun 06 2010 13:04:20: %ASA-6-611101: User authentication succeeded: Uname: cisco
Jun 06 2010 13:04:20: %ASA-5-502103: User priv level changed: Uname: cisco From: 1 To: 15
Jun 06 2010 13:04:20: %ASA-5-111008: User 'enable_1' executed the 'enable' command.
Both ssh and telnet log the same syslog messages. Which ever message you are interested in just add them to the mail list.
-KS
