WRP400 problem with wireless lan
Jun 6th, 2010
I have recently purchased a WRP400. Everything seems to work properly, wireless, ppoe wan and phone, but there is no way that I can connet 2 pcs through wireless lan. I tried both pcs with different os's (linux, win xp) so I'm sure there is no problem with them, and the work perfectly inside other networks.
I tried different parameters in router configuration and different firmwares (from 1.00.04c to 2.0) with no luck, can anybody help me?
Thanks.
streamlake Sun, 06/06/2010 - 08:27
I can ping the router from any pc's and internet (through ppoe wan) works on both.
Tthe router can ping both pc's but pc's cannot ping each other.
