SRSV A-to-Z configuration guide
Jun 6th, 2010
I m looking for end to end SRSV configuration including the CUE, UMG, Unity Cx, CUCM
Can anyone send me the link since I didnt found in the cco
Rob Huffman Sun, 06/06/2010 - 08:25
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
mamozig Sun, 06/06/2010 - 10:56
Thanks Rob
But I wasreffering to srsV not srsT
mamozig Sun, 06/06/2010 - 13:19
Sorry , but I have seen those links,i think they relate only  to the CUE srsv/umg  side which is the important one.
what I m looking for is the configuration needed end-to-end including  unity cx and cucm and any other component needed.
I would like to see the detailed configuration of the "whole picture"
David Hailey Sun, 06/06/2010 - 16:44
  • Purple, 4500 points or more
As a new feature and with 8.0 in a lot of churn, there is no one A to Z document.  You may want to take a look at this PDF, it pretty much gives the steps that are taken on Unity Connection.  Since SMTP is used to allow messages and data to be uploaded to the UMG, you either add them to ACL's configured within CUC or go with Allow Untrusted Connections.
http://www.cisco.com/en/US/docs/voice_ip_comm/umg/rel8_0/install/install_srsv.pdf
Other references:
http://www.cisco.com/en/US/docs/voice_ip_comm/umg/rel8_0/gui_admin_olh/add_central_vm_server_wizard.pdf
Hailey
Please rate helfpul posts!
