Setting uplink port on Catalyst 2900 series Switch
Jun 6th, 2010
Greetings, I'm working on my CCNA and I want to copy down the IOS to my Linux box via TFTP before making any major configuration changes (basically back it up).
I've noticed I don't have an uplink port on the Switch and not really sure how to go about this.
Also can I use CAT5 or will I have to use Cross-Over?
thanks
Leo Laohoo Sun, 06/06/2010 - 14:34
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
As long as the speed and duplex are set to auto then MDI/MDI-X is enabled.
Connect your host to the switch, give the switch an IP address and enable TFTP and you should be able to copy the IOS from the switch to the client.
Chris_M_Miller Mon, 06/07/2010 - 17:58
[quote]
[/quote]
I'm not sure how to confirm if MDI/MDI-X is enabled or not on the Switch.
Forgot to include this other detail.  All of the devices (Linux pc and Cisco Switch) are connected to a Linksys SOHO Router/Switch.  Will this make a difference?  I wouldn't think so as long both devices can ping each other.
thanks
Leo Laohoo Mon, 06/07/2010 - 19:07
  • Hall of Fame,
    2017 LAN, Wireless
In the interface configuration, enter the command "mdix auto".
