calls are forwarding to MVA DN !!!
Jun 7th, 2010
Hi all,
I configured Mobile voice access @ cucm 7.0 .. i can listen the prompt from system, after get login, system prompt asks for make a call press 1 ... after press 1 if i dial any mobile or PSTN number the call is forwarding to the Mobile Voicess Acces DN which i configured Under Media Resource Group ---> Mobile Voice Access !!!!!!
After get login i want to make calls @ PSTN  &mobile numbers !!!
can any one help me out what mistake im doing ??
Md. Mijanur Rahman Mon, 06/07/2010 - 06:01
Hi, how did you sure that it's forwarding to MVA DN again? Do you get the MVA system prompt again? or it's dialing out through any of your gateway?
anis_cisco Mon, 06/07/2010 - 07:13
Because if i dial any mobile number after press 1 (in prompt) the phone having same DN which i configured in MVA under Media Resource Group, is ringing ...
