LMS automatic change
Jun 7th, 2010
I have question about LMS application.
Is it possible organizing automatic configuration change on device if for example HUM fixed event such is 'device is down'?
If answer is positive, how I can configure it?
Joe Clarke Mon, 06/07/2010 - 22:07
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I'm not sure I understand the question.  Are you asking if it is possible to perform a configuration change on a device if HUM detects that the device is down?  If so then this is not possible.  If HUM detects the device to be down, then LMS cannot reach it to perform any change.  However, this is a perfect job for the Embedded Event Manager provided the device in question is running IOS.  EEM can react to a number of conditions and gives you the power to perform configuration changes.
More on EEM can be found at http://www.cisco.com/en/US/docs/ios/netmgmt/configuration/guide/nm_eem_overview_ps10591_TSD_Products_Configuration_Guide_Chapter.html .
amorkovin Mon, 06/07/2010 - 22:21
No, I mean LMS must perform change on other device not on the down.
