recertification date
Jun 7th, 2010
Hi Folks,
My CCNA will be expired on 12th June this year, The email I received from cisco says I have recertify my CCNA 'prior' the expire date.
Just wonderting, If I take the recertify exam on 12th June and pass the exam, would that be counted as successful recertify or I have take exam on 11th June or before that?
Thanks a lot
Thank you
Walter Solano Mon, 06/07/2010 - 05:10
You have two options, first pass any 642 exam before June 12th or the CCNA, but need to be done before June 12th.
Please rate this post if was helpful
Walter Solano
Cisco UCCX Specialist
davidxiayuan Mon, 06/07/2010 - 05:14
Thank you for your reply,
I was wondering if I can take the exam  on my certification expire date which is 12th June. And If I passed the exam, I will be able to recertify my certification.
Or
I have to take exam before 12th June which is 11th or ealier.
Walter Solano Mon, 06/07/2010 - 05:18
I guess that needs to be done before June 12th, but the best place to check that will be with pearsonvue support. This is the number, please call them and let us know what they say about this.
https://www7.pearsonvue.com/cisco/contact/
Walter Solano
davidxiayuan Mon, 06/07/2010 - 05:22
Thanks for your help, I called them this morning, the person on the phone told me, she assume it will be OK, but she asked me to double check with cisco.
I have raised a case with cisco support communite and online support. Hopefully I can have an answer from them.
I will update this post once I heard anything back from them
davidxiayuan Mon, 06/07/2010 - 07:24
Hi Brandon,
Thanks for your answer,  So does it mean, if my cert expiration date is 12th-June, I have to take exam and pass the exam on 11th or ealier that?
Exam taken and passed on 12th/June will be counted as invalid recertify?
David
Brandon Buffin Mon, 06/07/2010 - 07:25
Correct. You must recertify on the 11th or earlier. Passing an exam on the 12th will not recertify your existing certification.
Brandon
