CCIE Security Lab Document.
Answered Question
Jun 7th, 2010
According to the web site of "CCIE Security Lab Environment", the Cisco documentation CD is available in the lab room.
I have some cisco's products required for CCIE Security Lab, but I don't have any documentation CD.
Does it contains the IOS's guide such as Configuration Examples and TechNotes about IOS12.4?
Correct Answer by Brandon Buffin about 6 years 4 months ago
I don't think this exact document would be available in the lab. However, you can get DMVPN config examples. For example, you can drill down to Products > Routers > Branch Routers > 3800 Series ISRs > Configuration Examples and TechNotes and find a DMVPN example.
Hope this helps.
Brandon
Correct Answer by Brandon Buffin about 6 years 6 months ago
Yes, this should be the complete list.
Brandon
Overall Rating: 4.5 (4 ratings)
Brandon Buffin Tue, 06/08/2010 - 06:12
You have access to the Products tab on this page which allows you to drill down to a particular product and see documentation, config examples, etc.
Hope this helps.
Brandon
Correct Answer
Brandon Buffin Fri, 08/06/2010 - 05:19
Hope this helps.
Brandon
cisco_fun_4899 Sun, 08/08/2010 - 16:16
Hi Brandon,
Thank you for your help again.
I see. I'll train that scenario to be able to confugure without the document.
Tomotuki
