cannot create vlan on 2911 w/ios 15
ubuntu_guy
when I issue the vlan100 command at global
config I get;
Router(config)#int vlan 100
% Invalid input detected at '^' marker.
here is a sh ver with my license info.
Technology Package License Information for Module:'c2900'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      securityk9    Permanent     securityk9
uc            uck9          Permanent     uck9
data          None          None          None
11 Replies 11
Can you share the output of show vlan-switch.
Chetan Kumar
Router#sh vlan-switch
VLAN Name                             Status    Ports
1    default                          active
100  VLAN0100                         active
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        1002   1003
100  enet  100100     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        1      1003
1003 tr    101003     1500  1005   0      -        -    srb      1      1002
1004 fdnet 101004     1500  -      -      1        ibm  -        0      0
1005 trnet 101005     1500  -      -      1        ibm  -        0      0
Router#
Reza Sharifi
Richard,
You can not create an SVI on the router.  You can however assign vlan id under the physical interface
interface gi0/0
vlan-id xxx
Reza
correct me if I'm wrong but isnt SVI just for switching? This is a 2911 router.
2911 is an router , But if you have switch module then you can create SVI interface . Because i was having 1812 router and in that i was having 8 port switch module and i was able to create SVI interface.
But need to check wether 2911 Router support this feature or not.
Chetan Kumar
HI Reza,
I am in the process of replacing a Cisco Sw 3550 which is acting as a border router (connecting to provider and to the Lan with a default Ip route statement 0/0) with a Cisco 2911 router however, it seems that I need a Switch to have my vlans on it and only adding VLAN Ids on the GE INterfaces on teh new router. well, I do not have a Switch.
can I still do this?
Please advsie,
Masood
This is my fisrt time using the 2911, how is it different from the 2800 series routers that all
ow me to create vlans without having a switch module installed. I just think it's odd that I cant even create a vlan.
Thanks very much for your repleis, I very much appreciate the help.
Richard,
why vlan on the router?
You can have a router on a stick with subinterfaces with dot1q vlan tag without addtional switch module
http://www.networkstraining.com/cisco-router-on-a-stick-with-switch/
Francisco.
I always use a vlan on the router for the voice. I'll have a
hotspot hanging off the router as well, that'll also be a seperate vlan. I just like to keep stuff seperate where I can.
According to cisco you have to use the vlan-database, which is odd since that's on the brink of not supported anymore.
You gonna need to have EtherSwitch Service Module on your router to create a vlan SVI. Or the other option is to have the vlans on a switch and create the subinterfaces on the router to do inter-vlan routing between your vlans on the switch.
By having the  Cisco Enhanced EtherSwitch Service Modules, it will greatly expands the 2911 router's capabilities by integrating industry-leading Layer 2 and Layer 3 switching with feature sets identical to those found in the Cisco Catalyst® 3560-E and Catalyst 2960 Series Switches with POE for your phones.
Francisco.
