Modules
francisco_1 Mon, 06/07/2010 - 07:08
  • Gold, 750 points or more
For example the FWSM does not include any external physical interfaces. Instead, it uses VLAN interfaces. Assigning VLANs to the FWSM is similar to assigning a VLAN to a switch port; the FWSM includes an internal interface to the Switch Fabric Module (if present) or the shared bus.
https://www.cisco.com/en/US/docs/security/fwsm/fwsm32/configuration/guide/switch_f.html
Francisco
francisco_1 Mon, 06/07/2010 - 07:11
Likewise the ACE modules uses internal vlan interfaces.
francisco_1 Mon, 06/07/2010 - 07:49
The FWSM  uses the backplane of the switch to get connect to the network with a 5Gbps uplink to the backplane, which is potentially a lot better than the 1Gbps on a physical interface.
Francisco
