Chassis View error
Jun 7th, 2010
We have the "typical" error (LMS 3.0.1+CV 6.1.7):
Cannot find applicable device package for x.x.x.x:
This error could be due to one of the following:
- The device package for this device type is not installed.
- Device support for this device type is not available.
- You are trying to open a component inside a device.
To correct the problem, either install a device package for the device type, or open the
parent device to manage the component."
Looking through support, we have found:
Shutdown Daemon Manager, then copy all of the .zip files from NMSROOT/www/classpath/com/cisco/nm/xms/psu/pkgs/cvw to NMSROOT/MDC/tomcat/webapps/CVng/WEB-INF/classes/com/cisco/nm/cvw/devpkgs.  then restart Daemon Manager
We have problem with a SW6503, 6509 and 6513, but files are quite strange, i think
Joe Clarke Mon, 06/07/2010 - 22:14
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Are these switches running IOS or CatOS?  What is the sysObjectIDs of the switches that you cannot open?  When you copy the files, make sure the files copied have Full Control granted to casuser.
mserranocisco Tue, 06/08/2010 - 00:23
They are:
.1.3.6.1.4.1.9.1.282
.1.3.6.1.4.1.9.1.283
.1.3.6.1.4.1.9.1.400
They say it has been working till they deleted and added nodes again.
I have tried to delete package, and intall it again, and always the same error :-(
For Product(s) : CiscoView
Install Invoked by user : admin
The Package(s) Selected for Install :
Cat6000, Cat6000IOS
Successfully installed packages (2):
Cat6000(9.1) ,Cat6000IOS(30.0)
Installation Completed for : CiscoView
After deinstall/install packages, in www folder, only appear:
Cat6000.cv50.v9-1.zip
Cat6000IOS.cv50.v30-0.zip
So, i have to copy Cat6000.zip and Cat6000IOS.zip from MDC folder again!!!
Thanks in advance
