speaker sounds OK but handset has "tunnel" sound
Jun 7th, 2010
I am running 7965GE phones on a UC520 system.  Testing internal calls we ran into an odd problem.  A few phones have a
"tunnel" type sound when talking with the handset. The problem is the incoming voice sounds like it is in a tunnel.  The
problem phone sounds OK on the far end. Same phone using the speaker phone and incoming sound is fine.
Any ideas?
Diego
Overall Rating: 4 (1 ratings)
David Hailey Mon, 06/07/2010 - 10:51
  • Purple, 4500 points or more
Are these IP to IP calls or what?  Are you using a wideband codec such as G.722?
Hailey
Jonathan Schulenberg Mon, 06/07/2010 - 11:34
  • Cisco Designated VIP,
    2017 IP Telephony
Also what firmware version on the phone?
DIEGO ALONSO Sat, 06/12/2010 - 05:00
Finally got around to getting that firmware.  Phones are 7965GE and firmware is sccp45.8-3-2s.bin.
Thanks for your help.
Diego
Jonathan Schulenberg Sat, 06/12/2010 - 06:12
    2017 IP Telephony
Try upgrading the firmware to 8.5(3) or 8.5(4).  That version has issues; I have heard this complaint from other customers running 8.5(2).
DIEGO ALONSO Mon, 06/07/2010 - 15:40
These are IP/SCCP to IP/SCCP phones on our local LAN.  Codec is G.711u.  Will get firmware tomorrow when I get to the office.
